Clunking sound
giomachinegiomachine Member Posts: 2
edited March 2015 in Hyundai
just replaced front struts springs strut mounts every part to do with the struts are new got it all back together and when im backing up and turning right i hear this loud clunking sound any idead what it could be it sound like its coming from the front passenger side but im not 100 percent.
  • giomachinegiomachine Member Posts: 2
    it also has had the control arms replaced last year and has new tie rod ends
    You might check the torque settings on your upper mounting bolts---if they won't hold the proper torque setting, the threads might be stretched or worn, and this would cause a noise. Snug 'em up and see what happens.
