Cracked block on a EcoTech I4 engine
 dasshrubber
                    Member Posts: 1
dasshrubber
                    Member Posts: 1
                    My 2009 Vue developed a coolant leak into the oil at 130k km.  I had to have replaced.  GM has a technical note about this exact problem with the recommended fix: Engine Replacement.  The coolant was leaking into the oil at the water pump.
The Statement from the dealership states that there was a crack in the block near the water pump. The dealership was good and gave me a little help with the bill, but a block should not break like this. Is this a design defect with the block, and if so is their a class action already started?
