2010 Insight leaking water
matticus78matticus78 Member Posts: 2
edited March 2015 in Honda
Hi All,
I have a 2010 Insight that is leaking what seems to be water from a spot in the center of the vehicle roughly parallel with the front wheels. I've seen a number of posts suggesting that this is probably just the AC dropping condensed water, except that I haven't used the AC in months.
Can water leak from an AC when it hasn't been turned on for some time?
If it helps, I am 99% sure this is water; it is clear, and has no texture or thickness, and no odor.
Any info will be awesome!!
Best Answer
Answers
  • matticus78matticus78 Member Posts: 2
    I DO use the defrost pretty much every morning on my commute in. Thank you, that helps.
