Misfiring problem
I have a problem with my CTS 2005 3,6L that occurs randomly and can be described as following:
When speeding up, the engine starts hesitating and the check engine light will become blinking. Some times this symptom appears when starting the engine and in idle situation.
I consulted a mechanic scanning the engine and he told me that it's a misfiring problem on 2 cylinders (1 - 5) reporting this issue to the ECM itself and suggesting to replace it without checking the related spark, coil, wiring,...
Can I ask your advice please if should I replace the ECM or it may not be the cause of this misfiring problem?
Appreciating your answer
About the mechanic claim, it was simply based on previous problems with same car model, and he told me that usually the ECM will be damaged after this milage (180 000 M)
He didn't check any other component.
is it true and should I go for an ECM replacement which will cost me about 750 $ ?
A solid routine requires that the shop/technician actively troubleshoot the system while a failure is occurring, but this isn't universally supported. There is tons of pressure by consumers for shops to not charge for diagnostics and there is no shortage of people who not only condemn a shop for taking a scientific approach they actively preach that you should be able to just google the symptom and that will tell you what part to replace.
There is no magic machine that someone can connect to the car that tells the tech what s wrong. It quite often is labor intensive to do proper diagnostics. It also requires that the technician have a good game plan for and most of all knowledge and patience to diagnose a lot of the problems that cars present with. The consumer pressure to not charge for diagnostics makes learning to be that diagnostic technician a very difficult career choice. It seems there is always the next person in line who expects that techs will just know the answer to a given symptom. Based on only what you have written here it cannot be ruled out that this technician is succumbing to that pressure and just going with instinct instead of testing and proving what is wrong. That is the wrong approach, no matter how much pressure media and consumers try and put on the techs to lessen the repair expenses. If this hasn't been truly tested completely then you should not be replacing the computer yet. The catch is he could be correct and now testing correctly usually gets treated like it was a wasted effort and even a rip-off if it proves that the PCM itself is to blame.
First when watching the misfire counter in the live data stream, which cylinder(s) were reporting the misfires?
The engine load that you are describing would cause high secondary spark demand voltages, so if the spark could leak anywhere that is the condition that it would be likely to first occur. But you need to confirm the misfires with the cylinders that are affected and then start investigating for causes. Those deposits alone would not be enough to confirm as a cause especially because double platinum plugs are very resistant to in cylinder issues. It would be far more likely for the plug wire boots to be degrading and for carbon tracking due to micro scratches on the porcelain plug from the plug boots to become conductive and allow the spark to be jumping outside of the cylinder.
BTW, with the tendency to promote external spark leak issues because of how high secondary spark demand voltages are these days, just taking the plugs out to inspect them actually commits you to replacing them and the plug wires or else you are likely to cause a misfire to occur when there wasn't one before.
