Highlander Whining Noise
mike342mike342 Member Posts: 15
edited November 2015 in Toyota
Purchased a 2010 AWD Highlander, There is a whining noise coming from the rear end, possibly the differential. Is this normal in all Highlanders? If not can someone tell me what can be done to solve the problem.
Best Answer
Answers
  • rusty_cagerusty_cage Member Posts: 28
    How old are your tires? I have ran into this issue and almost let a mechanic change wheel bearing before I guy gave me this tip. since then I have seen the issue twice more and in both tires made the difference
  • mike342mike342 Member Posts: 15
    Noise was present before and after I installed new tires. When I lift foot off accelerator the whining noise stops.
    Thanks for the response.
    So the noise is present when u press accelerator but id gone while coasting?
    yes.
