2006-2007 Outlander Wind Noise
What I've notices is that as the window is raised and hit the top stop the glass deflects out slightly. I assume this must be reducing the force on the window seal and causing cabin noise, if i lower the window a fraction (so still closed but just off top stop) the noise reduced to a more acceptable level.
Has anyone else experienced this window seal issue. Is there a know fix of it. If you do suffer from side window wind noise try slightly lowering the window and see if that has an effect.
If you can share me with the picture of your solution I will be really glad.
http://outlander-forum.forumattivo.com/t38-fruscio-aerodinamico-dagli-specchietti-esterni
Very interesting
