2000 Chevy Prizm A/C Delete Kit? Use 2000 Toyota Corolla A/C bypass pulley?
Hi all.
I have a 2000 Chevy Prizm and the bearing is going on the A/C compressor, it makes an awful noise.However I don't want to put nearly $1000 into the car replacing the unit. My mechanic suggested I could get an A/C delete kit. After calling around and doing some online research it seems that GM doesn't make such a thing.
My question is could I use an A/C bypass pulley for 2000 Toyota Corolla for my Prizm?
In any event, it's hard to say without looking at both cars. In theory the Corolla kit would work but very often when two cars share an engine, there are often changes to mounting holes for various accessories. As long as you can return the parts, then go for it and see if it matches up. But don't let the compressor seize!
