Stuttering problem
kimgentner2013kimgentner2013 Member Posts: 5
edited January 2016 in Chevrolet
Had new fuel pump installed low idle feels likes it gonna stall when I break or come to a stop been to mechanic 4 times he said all codes are clear also reaplaced fuel pump really added end sea foam please help don't know what to next
    edited January 2016
    Lots of possibilities come up with stalling problems, from clogged fuel filter, faulty pressure regulator, vacuum leaks, IAC valve, bad injector, even a faulty ECM. Testing fuel pressure at the fuel rail with a fuel pressure gauge might be a good start.
  • kimgentner2013kimgentner2013 Member Posts: 5
    Thank you for your suggestions I am going to look to them all
  • tahoelt10tahoelt10 Member Posts: 6
    Having the same issues, fuel pump gauge fluctuating, transmission fuel stick broke, truck shaking, stabiltrak code up etc... Replaced fuel pump, fuel sender, and the volm manifold w/sensor which fixed most of the issues but now im having issues with the torque converter.
