Are you a current or recent car shopper who bought an EV and then installed solar – or who had solar already, making the decision to go electric easier?
OR
Are you a recent EV buyer (past 3 months) as a result of manufacturer incentives and dealer discounts on these vehicles, including year-end deals? Were you convinced to buy an EV after finding a good end-of-year deal, or due to uncertainty around which EVs will no longer qualify for full/partial EV tax credits in 2024? A national business reporter is interested in speaking with you. Please reach out to [email protected] by 12/15 if interested in sharing your story.
I have a 91 Mazda MPV. It has fire, fuel, and is in time but won't start. What do I check?
tblanchardtblanchard Member Posts: 1
edited January 2016 in Mazda
the van simply turned off. had it checked and has fire and fuel but wont start. checked timing, its good. what do i check next
Answers
    I don't know how you checked for spark and fuel but I can say that unless you measure these precisely, then eyeballing for spark and fuel may not give you an accurate picture.
    But let's presume that the spark is strong and the fuel pressure is up to specs.
    Next thing I'd do is get a NOID light and check for injector pulse. Another way to approach this problem would be to inject starter fluid into the air intake--this essentially by-passes the injectors momentarily.
    If the vehicle starts with starter fluid, then you may have an injector pulse problem, hence something electronic, and you'll have to drill down into the ECM and wiring harness, because the ECM grounds the injectors to open them. No ground = no open.
