Code P0455
Had fuel pump replaced then bought manufacture gas cap replaced relay 3 weeks ago now gas cap light is popping up engine light is on and is running worse everyday please any advice would be great
Smoke machines are often used to detect and fix EVAP system leaks
You could also have a fuel tank leak, which is possible given your recent fuel pump replacement
Also the EVAP canister fuel vent valve could be inoperative.
