1981 Mark VI problem
I just purchased a 1981 Lincoln Mark VI coupe with only 23,000 miles on it. It has been in a climate controlled garage and has not been started in about 6 years. I replaced plugs, plug wires,air filter,fuel filter,fuel pump,fuel pressure regulator,fuel injectors and computer. The car ran great with no problems. I drove it about 10 miles and then it just quit! After a while it will start and run about 5 minutes and quit again. Do you think it could be the ignition module? I am running out of things to replace.
Best Answer
Mr_Shiftright
Member Posts: 64,481
What did you do about the old gasoline that was in it? Was the gas tank dropped and flushed?5
Answers
Also, testing for spark is an easy matter using a simple spark tester you can buy at Autozone
