Electrical Issue
raniquaraniqua Member Posts: 2
edited February 2016 in Chevrolet
Hi. I have a 2010 Chevy Cobalt and there is no power going through it. I check the fuse box and everything is fine but still no power. However, I did notice there is a clicking noise coming from the fuse box. Can you help me?
  • raniquaraniqua Member Posts: 2
    I also got my car inspected yesterday and it passed hours before the issue occurred. No warning lights before then as well.
    Check for loose or corroded battery cables.
    Try a jump start. If that cures it, then you have some battery or charging system issue.
    If that doesn't work, then you might have a security intervention, or a bad brake light switch or neutral safety switch. For testing those things, you'd need to test for voltage at the starter solenoid as you turn the key.
