How can I fix my 2007 Ford Explorer transmission fluid tube that came loose?
porche2010porche2010 Member Posts: 2
edited March 2016 in Ford
My 2007 ford explorer tube for the transmission came loose. what can I do to fix this problem
Answers
  • porche2010porche2010 Member Posts: 2
    The chassis number is 1fmeu63e47ub63656 how can I fix this problem
    If the bracket that holds it broke, then you'll have to buy a new dipstick unless you have a friend who knows how to do some quick brazing or welding. You might also check to see that the O-ring at the bottom of the tube isn't worn out or missing, as this will cause looseness and leakage.
