A/C compressor clutch
lilbad1lilbad1 Member Posts: 2
edited April 2016 in Saturn
My daughter has a 2003 Saturn Vue 2.2 and it seems that the clutch if froze up... I have checked Freon level with a gauge that I use to top of Freon and seems ok... the vehicle has 170,000 thousand miles... are these compressors prone to failure and is there a "Quick Fix" without replacing compressor, orphis tube and dryer? Thank you... any information will help.
Best Answer
Answers
  • lilbad1lilbad1 Member Posts: 2
    Yes.. I believe it is froze up... when you try to turn on the A/C... the clutch smokes and I think I saw a "spark or two" and it puts the engine under a hell-of-a- load....
    Sounds like the compressor is bad
