Motor only runs when a spark plug is removed
dimebagbubbadimebagbubba Member Posts: 1
edited May 2016 in Ford
2002 ford explorer 4.6 won't start unless a spark plug is removed. Coolant busted out up from behind engine. Started running terrible now it won't run unless a spark plug is removed. Why will it only run while a plug is removed?
Answers
  • cmhj2000cmhj2000 Member Posts: 381
    edited May 2016
    Won't run or won't turn over?
    Coolant "BUSTED" out? Hydro locked? Head gasket? Lots of miles???
    Sure sounds like hydro-locking. Does that spark plug have any sign of coolant on it?
    I also wonder, if not a head gasket, if the valves are not opening on that cylinder for some reason.
