Charge Time Surprise and the Importance of Power - 2016 Chevrolet Volt
edited May 2016 in Chevrolet
I was surprised to find that it takes almost five hours to fully charge the 2016 Chevrolet Volt. A fairly slow onboard charger limits the amount of current it pulls.
    Is the internal charger upgradeable?
  • cameronrcameronr Member Posts: 38
    edited May 2016
    There's no available upgrade for the internal charger, and none planned for the 2017 model, either.
    EDMUNDS NEWS AND REVIEWS EDITOR
  • schild1987schild1987 Member Posts: 4
    That's the biggest gripe I have with my Spark EV. I don't think it would have cost a lot for Chevrolet to up the charger to 6.6, and then they could have used that tech in the Volt as well. I assume the Bolt will have at least 6.6 kW... maybe then they will put it in the Volt also.
  • thecardoc3thecardoc3 Member Posts: 5,871
    So you have the optional 240v charging station? Or was the Volt not completely discharged? The 110v system is supposed to achieve a full charge in 10 to 16 hours depending on the amperage setting and ambient temperature. The 240v system should take about four hours.
    The Volt was discharged at the time I plugged it in to our Chargepoint wall unit (which delivers a little less than 240v because it is a commercial station).
