Engine code PO745
maxima8maxima8 Member Posts: 14
edited May 2016 in Nissan
my transimsion some times kick and i get code PO 745 I install new solenoid but still the same i install new dropping resistor new oil, still the same maxima n1996
    The P0745 is detected when TCM detects an improper voltage drop when it tries to operate the solenoid valve
    So you might have to dig into the pressure solenoid wiring harness or consult a transmission expert.
