Clicking noise
raisincainraisincain Member Posts: 1
edited June 2016 in Saturn
when I turn key to start car there is a loud clicking noise somewhere behind the glove box, it quits after a while, what is the problem?
    Sometimes relays will react to voltage drops, so it's possible that circuit (whatever it is) might have corrosion or connection issues. The relay in question is apparently not getting a constant voltage supply and thus can't operate properly.
    It's also possible that the clicking noise is not a relay but a malfunctioning motor for the HVAC air diverter (blend door).
