Ford F-Series Real World MPG Numbers
Please give mileage figures for the 2005 F350, 6.0 Diesel, Crew Cab, DRW, 2WD, 4.10 LS rear end. Thanks
PF Flyer
In my opinion, these are all very good #s considering I get about 11 mpg with my '69 Chevy 307 running empty and drops fast when I pull a load, and I would be crawling if I pulled that boat trailer while he pulls it at 65 mph even up some sizable grades.
Even before my modifications, the best I got was around 14 highway. There is only 6700 miles, and the service guy said to wait until it breaks in, and then the mileage should start to go up??
Secondly, if you're like me, you're not driving like a grandma - like me, you've probably done Banks or Bully Dog exhaust, and love to romp is to make it make noise...that flat KILLS your mileage.
Combine incorrect calculations with less than conservative driving, and I'd say you're doing pretty good.
The towing mileage? Those 3.73 gears are too tall to try to tow with 35" tires - you need 4.11s or a little higher to adjust to normal operating ranges (engine and transmission) - you're working them pretty hard with the 3-4" taller tires and no change in gear ratios.
Even if the recalibration was done, that's still a lot more work for the engine and trans, especially when towing - just because the speedometer may be accurate, it doesn't account for the extra weight and rolling diameter your engine has to push around, especially when towing.
I have a Jeep Wrangler with the little 2.5L 4 cylinder, 4.10 gears and 31" tires. To the best of my knowledge, it has never broken 15mpg.
when I bought my '04 F150 it had a 35 gallon tank (factory upgrade) as did many trucks on the lot.
that's plenty big for me
F350 CC and you're getting 12 -13 mpg, that's really not all the bad. You don't say what engine or whether you're a 4x4, or 4x2. or long bed or short bed. You're a lot heavier, and have a bigger payload than the F150 yet you're getting comparable mileage! Still quite painful though when you have to fill up.
Have about 11k miles on it and running full-synth 5-20.
I've been pleased with these numbers, and I can say I don't baby it, but I also don't jump all over the gas either.
ANYBODY HAVE ANSWERS?
With the '99 F350 7.3L Powerstorke, you get 12,000lbs towing off of the "bumper" and up to 14500 if you use gooseneck/5th wheel.
Fuel mileage.....figure 16/20 for the F150 and 14/18 for the F350. 100K miles on a diesel is nothing, the engine is just being broken in. If it were me...I'd go for the F350 Powerstorke, but that's my $0.02. You'll be able to drive it just as long, if not longer than the F150 with 21K miles AND you get tons more towing capacity and the fuel mileage doesn't drop that much. If you chip it, you'll be able to get better fuel mileage than the F150.
i am averaging 16-17 hwy 13-14 city is that good or bad 400 odo
You could switch over to a diesel, they get better mileage than a gas engine pushing around the same amount of weight. However, diesel engines are more expensive to buy up front and in my area diesel fuel is about 30 cents more expensive per gallon than gas.
Don't know about midsize trucks, do have friend with a Ford Ranger who consistently gets around 20 mpg - but I could almost fit his truck in the bed of my F350.
You could do like me. My truck is a V10, and it gets 10-11 mpg in the city. It takes 39 gallons to fill it - it's pushing close to $100 for a full tank of gas.
-PR-
03 Ford F350 SuperCrew KingRanch 6.0L Powerstroke
04 VW Jetta GLS TDI
05 VW Passat GLS TDI
Since taking my foot out of it a bit and airing the tires up to 35 psi and not running the A/C I have been getting an avg mpg of 14.16 after averaging 4 tanks of gas.
Usually this truck was about a 12-13 mpg with my driving habits.
Currently my truck has 62,500 miles on it. 85/15% (City/Highway) I get 14.5 MPG. During short 1 hour trips on highway at 70+ MPH I get 16.5 MPG. Best ever 17.9 MPG. Pulling 2,000# trailer 200 miles over light hills in S. Alabama 13.1 MPG. I am thinking of buying a 2005 Tacoma Reg prerunner.
Anyone have any ideas. I would like to be prepared before I face off with the dealer.
Also, anybody know any particular trouble spots on that era F-150? It has about 120,000 miles on it, but supposedly everything works on it. I haven't seen it in person yet, though.
i get 14.5 in town driving like an old lady
shellcae
Check the oil pan - they're notorious for rusting through and getting pin-hole leaks. They're a pain in the butt to change, because you've got to raise the engine in order to be able to get the pan around a frame member. The truck may also be ready for new ball joints - Ford cheaped out and didn't put greasable joints in, so they start to go around that mileage
Also can anyone tell me why the rear seat in the F-250 xtra cab appears smaller than the F-150, and there is no head rest.
I test drove the one that I am thinking about buying, and it drives like a dream for a F-250. I've had half tons all the way up to a one ton and this one by far has the best ride. The only catch is that this truck was traded in only after 4600 miles due to gas concerns. He went with a diesel.
I just bought my loaded XLT 4x4 with the 5.4 big gulp..
Damn this hurricane is really killing us at the pump :-( .
My first 3 tanks have yielded 15 - 16 MPG. :surprise: ????
I am very interested in eventually modifing but think we better keep the warranty. :lemon:
How about some details on that throttle body spacer. :confuse:
Also no VIBRAtions, knock on wood!!!!
This truck has gotten a bad rap..???
If we can just improve mileage a little I will be pumped!
Thanks...........
I get 15-16 Hwy and 11-12 city, and that after I re-learned how to drive eg. the door locks do not look for almost 1 block ( slow acceleration) no fast starts...
My Ford Explorer 92 with 4 liter got around 25 Hwy and 18 city.. but I drove it fast too. Any one know the most optimal speed for the F-250?
Wow, that is slow. I don't drive that slowly--and I'm not making any plans to start. I have slowed down--but not that slow. That almost seems like a safety hazzard for traffic behind you.
