Key scratch repair - next step
magnumekmagnumek Member Posts: 53
edited July 2016 in General
Hello.
I bought a car with a "key" scratch across each side, as you can guess big scratch attracts other ones. I couldnt look anymore and decided to do something with this. I ordered a touchup which includes base coat and clear coat. I put the case on the scratch but not sure what to do next, I think it looks even worse at the moment.
Here are the steps that I made:
1) I took the car to the car wash
2) I washed the scratch with a wax remover prep solvent
3) I put 3-4 coasts (depends on how deep it was) on the scratch with a brush
What should I do now? should I put the clear coat on it or should I sand it a little bit to level out the base coat?
Here is how it was before and right now.
Before:
https://i.imgsafe.org/2332ddaa45.jpg
https://i.imgsafe.org/2332f3d495.jpg
Now:
https://i.imgsafe.org/2332cbc571.jpg
https://i.imgsafe.org/233308a690.jpg
  • thecardoc3thecardoc3 Member Posts: 5,871
    edited July 2016
    The easiest and cheapest solution would be to get a custom stripe kit that simply covers over the scratch. Otherwise, you are stripping, sanding, filling and repainting the whole side of the car..
    When scratches are that deep, there's not much you can do. These kits are generally made for much smaller areas of damage.
