Touchy (jerky) brakes
henryn
Member Posts: 4,289
2013 Volkswagen Passat TDI SE, 66k miles. The brakes are definitely touchy, one could even say "jerky". If you're stopping from 30 mph or more, you do not notice. If you're driving slowly, such as maneuvering back and forth to fit into a very tight parking space, you most definitely notice. The rotors look smooth and clean, and the pads are far from being worn out.
Any advice or suggestions?
Best Answer
henryn
Member Posts: 4,289
I had forgotten about posting this question, I should have came back and provided the answer. I ordered new Wagner ThermoQuiet brake pads, front and rear, from Amazon. Changed the pads, did not touch the rotors, problem solved.2023 Chevrolet Silverado, 2019 Chrysler Pacifica5
Answers
I park in two different parking garages (at work, at the gym) that are incredibly tight. I often have to maneuver back and forth more than once to get the car into or out of a parking space. This is at very low speeds, moving 5 or 6 feet, stopping, and then changing direction. It is very hard, almost impossible to do this smoothly due to the brakes jerking when applied at very low speeds.
