Visitor Agreement.
Answers
First thing I'd do of course is to check the fluid level and the tension on the belt. Also check for a leaking or swelling power steering hose. We are looking for anything that might cause a drop in hydraulic pressure.
If there are no leaks, and the fluid level is good, and if the steering improves when you hit the gas, and if the power steering pump isn't noisy, then it's most likely an issue with the steering rack's internal valving.
