A/C condenser coil cooling fan assembly
Anyone know about where to find a A/C condenser fan assembly for a 2000 Chevy metro? This one is apparently not what you normally find for sale. It is 11" across the top and only has two wires, one that plugs into the harness on the hot side and the other wire is screwed into the radiator support for the ground. It is mounted to the condenser with two brackets that are spot welded to the condenser.
Answers
Seems to me you could also adapt a universal fan assembly, like they do with hot rods.
