2010 T & C Is there a headlight relay in the system?
My T & C started to lose headlights. They blink on and off when turned on. They even have the left lamp blinking when the right lamp is on solid. When both are on, and you hit high beam, both will go off, or one go off and the other blink. Some times they will work correctly on a trip around town. Is there a relay, and can it cause this problem? Thank you.
Best Answers
Mr_Shiftright
Member Posts: 64,481
Well could be the notorious TIPM module that controls (among other things) the headlights. You'll probably need professional help with this one.6 -
retired8
Member Posts: 15
Thank you Mr. Shiftright. I'll look into that. Couldn't be the dash switch could it? Too simple?5 -
retired8
Member Posts: 15
Yes, took it to my favorite car place in all of Shreveport/Bossier and they fixed it for $109. Was able to reboot or reprogram the TIPM. Hope it stays fixed. Thanks Mr. Shiftright.5
