Toyota Corolla Real World MPG
This topic is for Corolla owners to report their actual MPG.
"Real World" Fuel Economy vs. EPA Estimates
I live in Texas. I usually drive 60-70 mph.
JB
My experience with '03 Corolla LE Automatic is that the car is VERY sensitive to weather temperature, much more sensitive than a couple of other cars I have driven. With 70% highway driving, my numbers vary between 32 MPG under 20 F in winter and 40 MPG above 90 F in summer.
Gang
I have a 2005 Corolla S, Auto - purchased March 30, 05 and now has 7741 miles on it. (100 mile commute per day).
Of my hour long commute, 1/2 is at 75mph 1/2 is in stop/go 20 - 55mph.
May actual fuel economy is 31.93 mi /gal with an average fuel cost of $2.06 per gallon. I use 87 octane, and have changed oil once - planning to switch to synthetic at my second oil change at 10k.
I track everything on my PDA with Two Peaks Personal Vehicle Manager, so I have up to date stats all the time.
I've replaced the stereo and speakers - just didn't like the sound of the stock stuff, but other than that nothing on the car has been changed. Though I am thinking about putting in a dash kit to make it look a little more fun.
Krissy
I have the S model with extra value package and I paid 15500+TTL last January. The fit and finish, the sporty look, plush interior and MPG, I'd say it is a good buy.
Having said that, Consumer Reports had 29 mpg on average with the same Corolla, so I'm not doing too bad.
Also, I had a 96 civic before and, despite the fact it was much less powerful, it consumed about 15% more fuel under the same circumstances.
When i am not using the A/C in normal driving conditions I get about 29-30 MPG in the city. During the Summer when I am using the A/C (90-115 degrees) I get about 26-29 MPG.
With about 90% freeway (65-75 mph) and 10% heavy city driving I get 35+ MPG on a tank.
Josh
nowadays i get 34-36 mpg highway and city combined but i know that just on the highways i still get 39-40 mpg consistently with ac turned on.
my driving habits are between two extremes -- at times i meticulously follow the corolla owners's manual guidelines for optimum fuel efficiency by chaning gears the the therin mentioned speeds. but at times i become a maniac trying to suck every once of horsepower the car has by changing gears at high rpm.
in all, i am very happy with my mpg but i wish the car had more POWER!
people, if you get a change upgrade your stereo and speakers. i did and you have no idea what you are missing. perhaps thays why you havent upgraded them yet
at 65 mph, 34 mpg at 75 mph. 7700 miles on the car.
The salesman was probably lying, but maybe just mistaken. Some automatics do get better mileage than the same car with a stick. It just has to do with the gearing of the final drive ratio.
I wish women were as dependable as this car is.
How in the dickens are you getting 35 mpg in the city ? Was it rated at 29 mpg city on the sticker, which normally no one gets ? Don't you have any stop lights ? I have the new Civic EX coupe and starting out with 25 mpg city only driving and the lights are red real long here in my city, sometimes between 2 minutes up to three minutes...The window sticker said it might get 30 city and 40 highway, which I have not driven on yet....
BTW, I tested the mpg before the first tank of gas was empty when it got to 100 miles. Does anyone think it could give a better number when it is over 600-700 miles?
Buy a Corolla with a manual transmission and put a lot of air in the tires.
The A/C was on, the cr.ctrl was used most of the time, and it has 20,000 miles on it.
I have a '97 Corolla CE 1.6 lt. 100 HP @ 5600 RPM. Still works like new (well, almost). My Brother and Father have newer models of the Corolla and tell me that there's room for improvement. One of the things my brother noticed on his '99 was that the aerodynamics we're awful compared to my '97. I can ride down the interstate at 80 MPH and notice some road noise and mild wind resistance in my '97, so my bro lets me test drive his '99 and WOW, he wasn't kiddin!!! The '99 can't handle 80 MPH on a breezy day, it was being pushed around like an ice cube on a hot skillet!!! the '99 has a stronger engine (120 HP @ 5600 RPM) but lacks the aerodynamics and weight to make it all worth while. My dad's '02 is similar to the '99. I have a good car that's almost 10 years old and one day (I dred this day), I'll have to get a new car. I'm sad that the corolla has been shrunk into a compact sized car. I'd like to see Toyota make a mid-sized corolla like my '97. Oh well...that's all for now. Tell me if you've noticed the same on the '98 and later model Corollas.
Just purchased a Corolla LE about a month ago. I'm happy to say that I've been getting 30 MPG city.
Hmm...I just recently measured my Corolla's mileage when I took a trip from Toronto to Kingston (approximately 250km apart). Good day, good weather. Driving between 100km/h and 105km/h (approximately 60 to 65 mph?), by the time I get to Kingston I got 5.6L/100km. Which is pretty good.
How do you convert to MPG? :confuse:
100 / 8 = 12.5 x 5 = 62.5 mph I think this is it.
Those are pretty round numbers, of course.
I will warn you.. I've been a "2 footed, ride the brake driver" in the past, but I'm trying for good MPG driving this new car. The tach on the LE helps a lot. If you take it easy on a start you can keep the RPM's under 2,000 and still not PO the people behind you.
I still catch myself goosing it from a light, breaking hard at stops, but I'm getting better. 32MPG 100% in town from someone that doesn't drive like grandma all the time, and the car isn't even broken in is nice....:)
My goal is 34MPG in town. And it seems like I've got a great chance at doing it after the break-in period. I was looking at getting a Yaris, but for only $1,000 more than a stripped down Yaris I got a totally loaded Corolla LE ($13,995 including cruise and CD changer) The good part is I think I'll get the same MPG as the little Yaris, but have a classy ride to boot! - Joe
What the hell is wrong with Toyota and Honda as well?
Consumer reports claims the 2006 Corolla gets 29 mpg combined, and the Yaris gets 36 according to CD!
How can it be that 12 years of car tech advancement has yielded absolutley no increase in mileage?
With gas at $3.00, mileage is what counts! Yet car makers are playing a shell game with us!
The Hybrid Civic = 37 mpg according to CR
Prius = 44 mpg accroding to CR
My Corolla can nearly achieve the Hybrid Civic's numbers and with 1994 technology!
The 1997 Civic HX(with CVT) got 44 mpg! Same as the prius but $10,000 less, and with 9 year old tech!
I hope oil prices hit $80 and stay there! The economy grew at 4.8% in Q1 so there is no threat of recession, and honestly America needs to wake up and get it'd head out of the sand! 30 or even 35mpg is not good mileage for a 2006 car!
The new Fit, from Honda, gets 35mpg! Same as my Corolla!
In England they sell a 1.2 liter version that gets 45mpg, real world, American equivalent!
Offer that over here damn it!
Its true what CD says, automakers want to get Americans freaked out about gas prices and into 25K hybrids, when they could get equivalent mileage from a 15K eco car!
How about this! I will pay Toyota 25K for an eco box that also has hybrid and is a diesel!
In Europe Renault and Peugot are coming out with 80mpg hybrid diesles! We have nothing like that in the states!
Only when Americans get raped at the pump will they cry out for sensible cars! Only then will they stop the outrageous "bigger is better" idealogy!
When the new Corolla comes out, as well as the redesigned Fit, I hope gas is at $4.00 so that these companies finally offer us those 1.2 and 1.3 liter engines.
The horsepower wars are irrelevant! Bring on the mileage wars!
