radiator fan will not shut off
oopbabeoopbabe Member Posts: 2
edited November 2016 in Lincoln
engine radiator fan stays on when the engine is off, I had to disconnect the fan in order to get it to stop running. is this a sensor problem , relay switch, or what is going on, is something stuck? a fuse ?
Answers
  • oopbabeoopbabe Member Posts: 2
    2003 Lincoln town car,engine radiator fan will not shut off??
    How long did you wait before you decided it wasn't going to turn off? Did you check your coolant level BTW?
