3000GT weight reduction
I have a 93 3000GT VR-4 and the thing weighs over 4,000 pounds and is slowing me down. What are some helpful and somewhat simple weight reduction techniques for this car? Thanks.
I guess you could trade your battery for a smaller gel type unit, that might get you 10-15 lbs (just guessing here)---yep, leave the spare at home (who gets flats anymore anyway?).
I rather doubt anyone is making carbon fibre body panels but you could check into that.
Probably 100 lbs less weight would (so they tell me) give you 10 hp at the flywheel....so shaving weight is expensive and the results won't be dramatic.
I don't recommend a lighter flywheel because on a heavy car a light flywheel can be a real chore to drive on the street.
Also I'm looking into a boost controller which according to 3Si.org should be a great performance upgrade. I was wondering if a 93 with 100k miles can handle that and what mods could be taken for safety.
Thanks again.
So if I were you I'd do a cylinder leakdown test and determine quantitatively what the condition of this engine actually is at the moment. And if you are going to raise boost you will have to thinking about additional cooling of the air/fuel charge and also bigger injectors---or you will run way lean and then KABOOM.
Ask Connor At the Tire Rack
He should be able to give you some answers!
MrShiftright
Co-Host
Now I'm wondering about an intake system (haha one step at a time). I was told that for a twin turbo a cold air intake system is not necessary and won't make too much of a difference. This same person told me to just go with the RAM intake. Is this true? Any information is always appreciated. Thanks.
