2004 Camry with 140,000 miles - throttle body failure?
maude604maude604 Member Posts: 1
edited March 2017 in Toyota
I noticed on one of the reviews someone had trouble with throttle body failure. Did anyone have this trouble? Joe
Answers
    I have read of more complaints about Camry 4 cylinder throttle bodies than what you'd normally expect, but I also noticed that when people complained of "throttle body failure", there were different explanations. Some cited corrosion, some said it was a cracked throttle shaft, others found it wasn't the throttle body after all, but the pedal positioning sensor. A few claimed that there was an electronic part that couldn't be replaced without replacing the entire throttle body.
    So I'm not sure what's going on here.
    What symptoms are you experiencing?
