2003 Tacoma - OEM or aftermarket?
paulmarspaulmars Member Posts: 9
edited April 2017 in Toyota
What are the best brands for:
front disk brakes
wheel bearing seals and grease
2003 tacoma with 68k miles on it. 2wd, 5 speed. 2.3L engine. No options except the enhancement package (AC, allow wheels, painted bumpers, and 2 extra front speakers).
No short trips under 5 miles. Rarely driven on the highway. No off roading, no mud. Although many of the roads here are packed shell rock and very old worn out asphalt. West central florida. 3 miles from the beach. Most times its just used like a car. very rarely anything heavy transported, although seven times since 2003 I loaded her up to and maybe even beyond the rated capacity.
Finally I need new front brakes and will repack the front wheel bearings at the same time. Once in 14 years not too bad, huh? Should I go OEM or are there equal or better quality after market parts available.
tks,
pa
Answers
    I think OEM is just fine in your case---OEM parts fit right and perform as engineered.
