2002 Cougar slipping gears tranny issues?
struggling_itstruggling_it Member Posts: 3
edited April 2017 in Mercury
i have a 2002 cougar automatic thats not getting into gear from at a stop in drive position and need to use shifter running the gears manually too roll .
It will slam into gear at high rpm if in drive and i know better not to allow that for happening
2-3gears works ok and no slipping or problem i live in the hills so coming home is a fight and worry please help im a single mom desperate and stressed Thank you hope you can help
    Needs to be diagnosed. Could be a valve body problem which is still way better than internal damage.
    Has the fluid level in the transmission been checked?
    Are there any transmission trouble codes being stored?
