04 malibu lt 3.5, engine stalls when engine is up to temp
I have an 04 malibu lt i recently purchased. 218k. car randomly stalls when up to temp. runs like a scalded dog when engine is cool. runs great when engine is up to temp when off idle. seems to die on idle more than anything. mostly does it at a stop but it has died a couple of times while coasting in gear. the car has had a new ecm installed, new battery, new alternator, was told it had a new fuel filter. thought i might have a dirty or malfunctioning IAC valve but i cant seem to find one on it. i dont know if im just not seeing it of if that function is programmed into the electronic throttle body. any ideas on a solution would be appreciated. thanks
Answers
I would replace the IAC if its giving you problems not clean it. I got one fairly cheap on ebay. Same thing with tps. don't buy from parts store, order it on ebay. They are pretty good.
