2001 Chrysler 300M Vacuum issues
true300mtrue300m Member Posts: 2
edited October 2017 in Chrysler
I have a 2001 300m, I had the vacuum line from the purge valve to the top of engine, I put it back on and found the vapor purge valve had a broken nipple. I put on a new one and the car still runs bad, could it be the vapor canister?
    Why don't you borrow a code reader if you can to help guide you as to what might be going on here. Right now you're working in the dark--although if there's a large vacuum leak somewhere, that would cause the car to run badly and also throw other codes concerning fuel mixture.
  • true300mtrue300m Member Posts: 2
    I'll take it to Autozone and get the codes, thanks
