2012 avalon drivers side mirror replacement
2102ac2102ac Member Posts: 1
edited March 2018 in Toyota
I have a base model 2012 avalon. I need to replace the driver's side mirror. I found one on ebay but it only says that it's compatible with the limited. This is the only after market mirror I was able to find.
Will this work for my car? If not, what other mirror is compatible? Any ideas where I can find a compatible mirror?
Answers
    What you'll need is a side view mirror that isn't for a Limited, but also you'll have to let the vendor know whether you have memory function or no memory function. I'd suggest a local wrecking yard or, of course, ordering new from the dealer.
    Here's one place to search used: www.car-part.com
    As you will see, a used mirror might run $150. You should compare this price to the dealer's price.
