Double Stranding Leads to Replacement Battery, Software Change - 2017 Chevrolet Bolt EV Long-Term Ro
Edmunds.com
Double Stranding Leads to Replacement Battery, Software Change - 2017 Chevrolet Bolt EV Long-Term Road Test
Though its battery pack has since been replaced under warranty, our early-build 2017 Chevrolet Bolt EV stranded two drivers and may have prompted a recall.
This sort of thing shouldn't be happening in EVs today, and it really hurts the image of reliability that EV advocates promote.
Now you guys will have to restart your battery degradation observations, etc. I recommend keeping the car longer to see how it does.
As for EVs and their reputation, I've had so many good experiences with a wide variety of cars that this really feels like the statistical anomoly that it is. Still, ramping up any new model is potentially problematic, especially one that's completely new and pushing the envelope with 238 miles of range in a low(ish) buck car. I 'm just peeved that image managament thinking stood in the way of this getting flagged and repaired before we got stranded -- twice. Hoping a thing doesn't happen doesn't make it not happen.
Twitter: @Edmunds_Test
GM cars have OnStar, and your Bolt is probably still under the introductory full access subscription. If you have any sort of issue press the blue button and request them to run a diagnostic. If they pull any codes they will have them sent to your local dealer.
Signed - Owner of 3 Volts and 1 ELR
BMW-high pressure fuel pump failures in such numbers the dealers were running out of parking space.
Mercedes-Benz- The 7G Tronic gearbox debacle. After redesign 11 (IIRC) they got it right.
Jaguar-all their V6 and V8 motors up to 2015 have a fragile design of water pump. If you don't pull over the second you get a "low coolant" warning, you risk toasting the motor beyond repair. The really weird thing is that you never get any change indicated on the temperature gauge.
