Climate controls
piston172piston172 Member Posts: 1
edited June 2018 in Toyota
Clock stopped working first then the ac button light went out and now the ac stoped quit working I’ve looked at everything I could think of! All i know it has something to do I with the dash controls
Answers
    Not much to go on here. If you are working without a professional scan tool, not much you can do except the basics: Check battery connections, check all your fuses, and make sure the charging system is putting out proper voltage.
