We are aware of the login problems affecting the forums, and appreciate your patience as we work on a fix.
Did you recently purchase a new Tesla, Rivian or Lucid vehicle directly from the manufacturer and willing to share how your experience compared to previous vehicle purchases made through a traditional dealer? A reporter would like to speak with you; please reach out to PR@Edmunds.com by 2/19 for details.
Malfunctioning gas gauge
ScottdanScottdan Member Posts: 1
edited August 2018 in Toyota
Even though gas tank is full, needle is reading empty.
    edited August 2018
    You'll have to test to see if the sending unit is operating properly and if so, they you'll have to test at the gauge cluster. These tests require a wiring diagram, a VOM meter and, of course, the mechanical knowledge. So the possibilities are sending unit, gauge itself or wiring to and fro. Checking the sending unit will properly require dropping the gas tank.
    Here's a discussion that explains how to do it but this is for a 2002 model, so I wouldn't use their wiring diagram.
    https://www.justanswer.com/toyota/af6cy-fuel-gauge-dte-not-working-sequoia-fuel-sending-unit.html
