trans problem
Need some help ! Unfortunately i live in small town and no mechanics can
run diagnostics on my 04 x series jag. They have no clue.
What tran.is doing : Sometimes from reverse or park to drive it doesnt
move unless i put it in low 1 then back to drive .
Also feels sometimes like it might be driving in lower gear.....guess i should look
what tach reads. I did have one mechanic who put in a tire sensor...he thinks...
and seemed to run ok for about 2-3 months.
Is my trans ruined or can a different sensor fix it ?
Best Answer
[Deleted User]
If the shift solenoids aren't engaging or moving properly or hanging up, then it would cause similar symptoms.
Scanning for fault codes is, as @Mr_Shiftright stated, probably the only way to determine if it is electrical, computer or mechanical.
I would put my guess on a sticking shift solenoid/valve.
Either way, it's a Jag and not going to be cheap.5
Answers
You REALLY need to find a scan tool that can extract codes from the ECM and the TCM.
If you're really lucky, maybe you'll have a bad range selector switch on top of the transmission.
You could also have water intrusion into the TCM module, or corrosion at that connector.
Or, you might have to buy the whole enchilada, which would be painful.
I'm thinking (just guessing) that your problem might be electrical, which is a good thing. If you had one of the usual X-type shaft breakages, your car wouldn't move at all.
I would think that any professional mechanic's scan tool can scan the TCM for codes.
