I have an Idle problem.
With engine running, out of cold loop, I turn on the lights idle drops to, say from 850RPMs to 600RPMs and doesnt recover unless you turn off the lights, and if you turn on the heater fan also at the same time, RPMs drop to 3-400 RPMs, just hardley running. I also driving about come to a stop, and the engine idles down to 600 RPMs. Ive replaced Idle air control valve, the old one was worn out, new fuel pump, and fuel regulator on top of the TBI, I thought about the MAP sensor, but I dont want to buy things that really arnt worn out or broken, if you get my drift? Any clues? Help!
Best Answer
LilTimmy Member Posts: 6
Thank you Mr. Shiftright! I bit the bullet, bought another Alternater, I always have been skeptical about this alternater just because of the noise it made ( not having any better sence to realize that someting was wrong with it) but that cured the problems, no more noise, idles just fine with the lights on and fan! Great! Thanks for the encouragement and a little push in the right direction.0
Answers
http://www.qualitypowerauto.com/pages/AmperageLoadCalculator.php
I suppose that a bad bearing in the alternator could cause excessive draw on the engine itself. I think I remember that normally an alternator under load consumes something like 7-8 horsepower.
Did you check alternator belt deflection. If you push on the belt, it should move no more than about 13mm.
