how do i check relays with a test light on a 1997 dakota
Thumper33Thumper33 Member Posts: 7
edited September 2018 in Dodge
I replaced the IOD fues and it fixed some of my problems . rurn indecator lights do not work , washer fluid indicator is on as well as the air bag and break . again all the fuses are fine but i only have a test light how do i check relays
Answers
    I think these problems may not be related. The washer fluid could be the sensor located at the bottom of the fluid reservoir and the air bag and brake lights might need to be tracked down using a code reader or scanner.
    It's unlikely your washer fluid or air bag is attached to a relay because these aren't hi-amp circuits. Relay are used for things like headlights or cooling fans.
    However, if you want to check relays, here's a good TUTORIAL:
  • Thumper33Thumper33 Member Posts: 7
    ok i got the relays checked they are all fine , fuses are fine . i went threw and looked for broken wires and things with the washer fluid and it went off . i belive the break is the switch it has been on the longest. the ABS is the one im worried about .
