Changed radiator, now tranny won't shift into overdrive
JnybobJnybob Member Posts: 1
edited September 2018 in Chevrolet
Hi Folks, I removed my radiator, cleaned it, then re-installed. Now it seems my transmission won't shift into OD. The radiator has oil cooler lines, and transmission cooler lines. Could I have caused this problem when connecting the tranny cooler lines? Would air, or water in the lines be the cause of this problem? Thanks in advance for your help.
Jnybob
