What 2 color wires I cut from my ignition switch to wire a push button start
I have a 2008 Jeep Wrangler X and it won’t start. Apparently The ignition switch actuator pin is what is messed up. So I show a video online where a guy had the same issue as me and if you try to run a wire to the starter so you can touch the wire to the positive battery terminal to start the Jeep it will just turn over but never start because you don’t have power running to everything you need to start your Jeep. So he wire a push button start right to the wires coming out of his ignition switch. So all he had to do was turn his key on to run where everything comes on and hit the button and his Jeep started right up but his Jeep was older then mine and I only have 4 wires coming out of my ignition switch and I can’t find anywhere what 2 color wires I cut to wire a push button start into my ignition switch so all I have to do is put my key in my ignition turn it to run so everything comes on and start my Jeep with the push button. Can anyone tell me what 2 color wires I cut to do that?
Answers
Sounds like all this guy did was apply voltage through a button, and he got that voltage from some terminal on the ignition switch.
But if your ignition switch is not sending voltage to the ignition circuit, wiring in a button isn't going to solve your problem. You don't want a button energizing your ignition, because the minute you lift off the button, the car will die.
If you have a dead contact in your ignition switch, you should fix it the right way. Cutting and joining wires from someone's advice on the Internet is asking for trouble. You'd be better off finding out how to install a new ignition switch.
https://www.autopartswarehouse.com/engine-and-drivetrain/electronic-control-modules-ignition-and-distributors/ignition-actuator/dorman/rb924739?apwcid=gglpla&gclid=Cj0KCQjw9NbdBRCwARIsAPLsnFaNI1iT81GPbLUBRRbgnFKXK5PpCwUPG3yaCcENf8zuei3VzkARkOgaAntdEALw_wcB&gclsrc=aw.ds
