Transmission shift issues
RickDeLoachRickDeLoach Member Posts: 1
edited November 2018 in Toyota
Transmission "itermediately" won't shift from 3rd to OD. About 70MPH RPM 4K
Any input is appreaciated
    With situations like this, it always helps to check a) your transmission fluid level and b) the last time you had a transmission service.
    Also hook up a professional scan tool that can access codes from the TCM module. That might also give a hint if the issue is electrical, such as gear ratio, speed sensor, solenoid defect, TCM, and also may relate to transmission temperature.
  • CrickettCrickett Member Posts: 1
    Only have problem first gear hesitate s but not all time  have had a wheel sensor installed didnt help but hesitates fine all other gears really dont thnk its fully transmission
  • rickdonrickdon Member Posts: 123
    Maybe an elec rated issue. Are you getting a check engine light?
  • Lilsnoop213Lilsnoop213 Member Posts: 1
    No
