Srx runs rough .push on gas pedal and it comes out of it most of the time. The engine doesn't mis
AuctionsrxAuctionsrx Member Posts: 1
edited November 2018 in Cadillac
Code said misfire cyl 2 ,coil and plug is new , I paid$400 @auction and want it for a winter family all wheel drive SUV. No rust . really in GREAT CONDITION, should I find another motor to throw in it or is this an easy fix??
Answers
    Check the injector pulse in cylinder #2. You can also switch the coil with another cylinder, clear the codes, run the engine and when the CEL comes on, re-read the new code and see if the code followed the misfire to a new cylinder or not.
