09’ outback awd problem
Last year my outback started making a “growling “ sound, coming from the front(ish) . Lewder the faster and didn’t stop when in neutral. Was more pronounced when turning left? Eventually awd warning light went on, a couple of days later rear drive-shaft failed. Had that replaced, diagnosis code indicated that the awd drive warning was because front left speed sensor had failed. Reminder warning light came on weeks after the growl started.
6 months later growl is back?
( probably a coincidence, but there is a lot more break dust on right wheel than left?)
Anyone have any thoughts?
Answers
Are you running all tires the same size and same wear pattern?
