Hard to shift into first?
So I bought a 04 g35 (only 126,000) with a stage 2 clutch (put in about 2k miles) and a lightend flywheel. I’ve noticed that when I compress the clutch and shift into first it takes some force to get it into 1st gear. If I keep the clutch compressed I can shift from 1st to neutral then back to 1st with no issue. Once I release the clutch and compress it again 1st gear requires the same pressure again. Any help would be great!!!
Answers
What might happen if you pumped the clutch several times before putting it in 1st?
