I got a 2007 Toyota Avalon the only turns over won't crank up I've changed the fuel pump, fuel press
I got a 2007 Toyota Avalon they only turns over will not crank up have changed the battery the fuel pump relay the fuel pump,fuel pressure dampers and it ran good for awhile then I cut it off and BAM rite back to doing the same thing won't start just turning over please help me
Answers
On SOME cars (but not all), you can watch to see of the tachometer bounces while you are cranking the engine--if it does, then you know at least that your CPS sensor is working.
