5-speed trans won't shift into reverse
Guy_G123Guy_G123 Member Posts: 1
edited March 2019 in Kia
Transmission won't shift into reverse and is hard to downshift.
    edited March 2019
    Check the fluid level in your clutch master cylinder for starters. It's also possible, if your vehicle has high miles, that the clutch is just wearing out.
    Bleeding the clutch hydraulics might help, if there's air in the system, but that doesn't cure the problem, of how the air got in there in the first place.
