Mitsubishi vibration problems
Mitsubishi has a terrible design problem and I will not be recommending this vehicle any longer. Road salt.and dirt builds up on the rim and axle and the vehicles start to shimmy like there is something terribly wrong- as bad as a flat tire or needing a wheel alignment. It take very little dirt and can build up ( in BC ) in only 300 or so Kilometers. It takes a very, VERY meticulous cleaning to make sure there are no- and I mean NO- little clumps of dirt left behind any wheel spoke or build up on the axel or you will be at the car wash again. The dealers know about this problem as it is the first thing they tell you to do when you call about vibrations.
