Multi Function Switch
Just ordered my third multi function column switch again in 17 years. This time a turn signal / hazard signal failure. Both fuses good and 12v to them good. Thought it might be original flasher but replacement didn’t help. Turns/flashers prior started acting up and would work if you snapped the hazard button a few times. This stopped helping a few days ago. Getting no voltage reading from the plug that powers the flasher (three prong flasher). Big difference this time from previous failures is that all other functions work fine on the column switch. Since snapping the flashers button was the last thing to make the turns/flashers start working again, I’m assuming that part of the multifunction went bad so the only thing left to do is try a new unit. Anyone have this exact scenario before?
