Ford Explorer Power Port Problems
I have a 2004 XLT and an issue with the center console Power Socket (Cigar Lighter). I am getting no voltage to the one in the center console in front of the stowage box, but the one for the rear passenger is working fine. I have checked the fuses (15A) and all is ok - I have ben through every fuse in the box just in case and all are ok. Is there a relay that I need to look at? I have checked the manual and the Cigar Socket is not listed as utilizing a relay. Anybody have any ideas on what else I can look at? Next step is to remove center console and start tracing with a meter.
Regards
Richard
Regards
Richard
Please help, I'm at my wits end trying to get this to work.
Replace those fuses, you should be back in business then.
I have the same problem with a 1996 Explorer XLT, the accessory power ports do no power off when the ignition is switched off leaving the GPS running. Was there any suggestions on this?
